Use Jira for operations spaces
This page is for business spaces
To check whether you’re in a business or software space, select More actions (•••) next to the space name in either the header or the sidebar. At the bottom of the menu that opens, your space details will be shown.
オペレーション チームは、オフィスの移動からサイトの監査まで、あらゆるる種類のプロジェクトを行います。
The project management template in Jira business projects is an ideal base for managing short-term and delivery-based projects.
テンプレートについて
Ideal for projects of any size, any duration, and for any deliverable
マイルストーンの追跡に使用でき、アクティビティの期限を設定できる。
簡単にカスタマイズしてレビューやブロックなどの追加手順を含めることができる。
すべてを把握する
You're able to view the status of every work item on the board, including who’s working on what, and if it’s overdue.
バージョンを使用してマイルストーンを追加する
Projects often have 'checkpoints' or milestones that need to be reached in order to keep the broader project on track. In business spaces you can use versions as milestones. Once you have versions set up, you can organize work into different versions.
See Organizing work with versions.
管理部門に報告する
Projects are usually made up of well-defined, specific, measurable activities that have one major deliverable or goal. This makes project reporting even more critical to ensuring things get delivered on time. Jira business spaces include built-in reporting, but you can also use your dashboard and custom filters based on your searches to monitor activities.
カスタマイズ
Jira は高度なカスタマイズが可能です。一般的なカスタマイズの例を次に示します。
Adding additional steps to the workflow (such as approvals) to fit the way a project works
Changing the layout of work items to capture specific information
Use labels to track groups of work items related to project phases or workstreams
この内容はお役に立ちましたか?
