Fix errors in a space import
This is a troubleshooting guide for importing data into Jira. Refer to this page to resolve any errors you might come across while importing data using our new import experience.
If your import has failed or is partially complete, an error log will be sent to your email, or you should be able to download it at the end of the import. To find a solution to an error, use Ctrl+F or Command+F and enter the error code from the error log.
You need to be an organization, site, or Jira administrator to use the new import experience.
In addition to administrators, users with permission to create team-managed spaces can create and import data into team-managed business spaces but won’t be able to move users. Instead, user fields in the new space will be unassigned and user tags in comments will appear as plain text.
Import errors
Here’s how you can resolve errors you may encounter while importing data using a CSV file or while directly importing data from Asana, ClickUp, monday, and Trello.
Error code | Why does this error occur? | Solution |
DT001 | Locale, date, and time values don't match the selected format |
DA002 | Locale and dates don't match the format selected |
NU003 | The number fields contain letters, special characters, or spaces | Remove special characters (e.g., commas, periods, or slashes), spaces, or letters from the number fields in your CSV file.
CS004 | The CSV file may contain the following issues:
| Check your CSV file for:
Contact support if you need assistance with this error. |
EM005 | The email addresses in the file aren't in the correct format | Check the email addresses in your CSV file.
UR006 | The URLs in the file aren't in the correct format | Check the URL formats in your CSV file.
IS007 | One or more Summary fields are empty | Make sure Summary field isn't left empty in your CSV file. |
TE008 | The Original time estimate, Remaining time estimate, and/or Time spent fields may contain the following issues:
| Check and remove special characters (e.g., commas, periods, or slashes), spaces, or alphabets from the number fields in your CSV file.
PA009 | Invalid personal access token |
ON014 | Organization name too long | Make sure that the organization names in your CSV file are not more than 200 characters. |
