We're updating our terminology in Jira
'Issue' is changing to 'work item'. You might notice some inconsistencies while this big change takes place.
Manage projects, shortcuts, versions, reports and more
Switch between projects
Work across multiple projects more easily by switching between your recent and starred projects in the sidebar on the left.
Star your business projects
You may want to star certain projects that you frequently work in so you can access it quickly when you sign in. One way to star a project for Jiraprojects:
  1. Next to your board’s name in the sidebar, select more actions (•••), then Add to starred.
  2. Your project will then appear under Starred in your sidebar.
Another way is by:
  1. Next to Projects in the sidebar, select more actions (), then select Manage projects.
  2. Hover your cursor over the first column with the star in the table, then apply the sorting to view your starred projects first.
Change views in your project
Once you’ve chosen which project to work on, you can choose which view you’d like to work in. You can choose from:
The view options will be in the project navigation below your project header.
