Import data from a software space to a business space
Moving your work from a software space to a business space just got easier.
Using the Jira importer, you can directly import your existing software data to a new business space. This helps save the effort of manually moving data and ensures all information stays relevant and accurate. Not to mention, your teams now get to work in the Jira that best fits their use case.
Importing data
To directly import your data using the Jira importer:
  1. Next to Spaces in the sidebar, select Create space ().Select Import data.
    1. You can also navigate to the same page from Settings (⛭), then System. Select External system import in the sidebar.
  2. Select Jira (software space) from the list of apps.
  3. Select the software space from where you’d like to import data from. Once you select the space, the About this software space section will display the number of work items in the selected space that will be imported.
  4. Select Next.
  5. You’ll need to create a new business space for where you want your imported data to land. You can customize the name of the space, its access and key type. Then select Next.
The space key and type will automatically be selected for you. You can customize the key as needed. You can also change the name and key later from your space settings.
The space type cannot be changed and will be imported to match the software space from where you are importing the data.
6. Review the details for your new space. The screen will summarize how your software space data will be imported:
  • Field mapping: View and customize how the standard and custom fields in your software space will be mapped in your business space.
  • Import users: Bring users from your software space to your new space so they remain assigned to the work. These users won’t receive any notifications when they’re added to the new business space.
  • Import attachments: Select whether to import attachments into your new space.
Any people field, @mention, comment with an attached name, and reporter or assignee fields will be left blank if users from the software space are not imported to the business space.
9. Select Import when you’re ready to start importing your data.
The importer will automatically start bringing over the data from the software space in the background. You’ll find a progress bar that will indicate the status of your import.
You can continue to work on other things and return to the page to see the progress of your import.
Once the data is imported, work items from your software space will show on the board view as work items in your new business space. More about the board view
If your import fails or is partially complete, you can download an error log at the end of the import. Use the troubleshooting guide to fix errors and try importing your space again.
Edit fields in your business space
You can edit how the software space fields are imported into your business space during the import.
The Review details screen will summarize how your data will map to the new business space. Select Field mapping. This is where you’ll find how your data has been automatically mapped.
This is where you can:
  • Edit how your software space data is mapped.
  • Use the toggles to indicate whether or not to include specific fields in your import.
To edit your fields:
  1. Select the dropdown of the field you want to edit.
  2. You can either select an existing field from the options provided or select a custom field type that best suits the format of your field. If you select a custom field, it’ll take the same name as your software space.
Summary is a required field in Jira. It can’t be modified or excluded from an import.
Any changes you make will be automatically saved in real-time. Once you’ve edited your fields, head back to the Review details screen.
Supported software space field types
Jirabusiness spaces have two types of fields:
  • System fields: These fields are “built-in” or part of the software by default.
  • Custom fields: These fields are customizable based on the user’s needs.
The data from your software space field types can map to either system fields or custom fields in business spaces.
Unsupported software space fields
The following software space fields can’t be mapped to either system or custom fields in business spaces. These fields aren’t supported as part of the import:
  • Mirror
  • World clock
  • Progress
  • Creation log
  • Auto number
  • Button
  • Formula
  • Board relation
  • Doc
  • Dependent dropdown
  • Story point estimate
  • Sprint
  • Environment
  • Epic label
  • Epic name
  • Epic status
  • Team
  • Versions
