Import data directly from monday into Jira
Moving your work from monday to Jira just got easier. Using the monday importer, you can directly import work into Jira. This helps save the effort of manually moving data and ensures all the information is relevant and accurate.
Importing data
Admins can create and import data into both company-managed and team-managed spaces.
Users with the permission to create spaces can only create and import data into team-managed spaces but won’t be able to move users into the new space. All user fields in the new space will be unassigned and user tags in comments will appear as plain text.
To directly import your data using the monday importer:
From the navigation bar, select Spaces, then Create space, then Import data from the sidebar.
You can also navigate to the page through your settings. Select Settings (), then System, then External System Import on the sidebar.
Select monday from the list of apps.
Select the monday workspace and board from where you’d like to import your data from. Once you select a board, the About this monday board section will display the number of tasks in the selected space that will be imported.
Select Next.
Create a new software or business space in Jira. This is where your data from monday will be imported. You can customize the space's name, access, and key type. Select Next.
The Key will automatically be selected for you. You can customize it as needed. You can also modify the space name and key later from space settings.
If you’re creating a new software space, your data will be imported into a Kanban template.
Next, review the details for your new space. The Review details screen will summarize how your monday data will be imported.
Space hierarchy: View how the structure of your monday board will be replicated in Jira.
Field mapping: View and customize how your monday standard and custom fields are mapped in Jira.
Import members: Bring members from your monday board to your new space so they remain assigned to the work. Note that these members won’t receive any notifications when they’re added to the new space.
App admins can only move existing users from the site into the space. To add new users, contact an organization admin to invite them before proceeding with the import.
Import attachments: Select whether to import attachments into your new space.
Select Import when you’re ready to start importing your data.
The importer will automatically start bringing over the data from monday in the background. You’ll find a progress bar that will indicate the status of your import. You can continue to work on other things and return to the space page to see the progress of your import.
Once the data is imported, refresh the page to see the work items on your board.
If your import fails or is partially complete, you can download an error log at the end of the import. Use the troubleshooting guide to fix errors and try importing it again.
Structure your monday project in Jira
When you use the monday importer, it directly gathers information from your account and creates a space in Jira with a similar structure and hierarchy.
Here’s how your monday project data will be structured in your new Jira space:
Groups from monday, will be imported to Jira as one of the following:
Status
Epic
Category
Items from monday will be imported to Jira as work items.
Subitems from monday will be imported as subtasks. To maintain a similar hierarchy as monday, each subtask will be linked to a work item.
Once your monday board is imported, you can customize the hierarchy to your needs.
Epics can be renamed, but the information on this page is relevant, regardless of whether your space uses the name epic or any other name.
Edit fields in your space
You can edit how the monday fields are imported into your Jira space.
The Review details screen will summarize how your data will map to the new Jira space. Select Field mapping to see how your monday data has been automatically mapped.
This is where you can:
Edit how your monday data is mapped.
Use the toggles to indicate whether or not to include specific fields in your import.
To edit your fields:
Select the dropdown of the field you want to edit.
Select an existing field from the options provided, or select a custom field type that best suits the format of your field. If you select a custom field, it’ll take the same name as your monday column type.
Note: Summary is a required field in Jira. It can’t be modified or excluded from an import.
Any changes you make will be automatically saved. Once you’ve edited your fields, go back to the Review details screen.
Supported monday column types
Jira has two types of fields:
System fields: These fields are “built-in” or part of the software by default.
Custom fields: These fields are customizable based on the user’s needs.
The data from your monday column types can map to either system fields or custom fields in Jira.
Column types in monday map to Jira fields in the following way:
monday column types | Compatible Jira system field | Compatible Jira custom field types |
Name | Summary |
Checkbox |
| Checkboxes |
Color Picker |
| Text |
Country |
| Text |
Date | Due date | Date |
Dropdown |
| Multi-select |
| Text | |
Hour |
| Text |
Item ID |
| Text |
Link |
| Url |
Location |
| Text |
Long Text | Description | Paragraph |
Numbers |
| Number |
People | Assignee, Reporter | User, Multi-user |
Phone |
| Text |
Rating |
| Single-select |
Status | Status, Priority, Labels | Single-select |
Tags | Labels | Multi-select |
Team |
| Text |
Text |
| Text |
Timeline | Due date | Date |
Vote | Votes | Multi-user |
Week |
| Date |
The following monday column types will be mapped automatically in Jira in the following manner:
Dependency in monday will be imported as work item links.
Files in monday will be imported as attachments and web links.
Subtasks in monday will be imported as subtasks, for which the linked work item will be the parent field.
Unsupported monday column types
The following monday column types can’t be mapped to both system or custom fields in Jira and aren’t supported as part of the import.
Mirror
World Clock
Progress
Creation log
Auto number
Button
Formula
Board relation
Doc
