Import data directly from ClickUp into Jira
Moving your work from ClickUp to Jira just got easier. Using the ClickUp importer, you can directly import up to 10 Lists from ClickUp to Jira. This can help save the effort of manually moving data and ensure the project information is relevant and accurate.
Import data from ClickUp
You must have the following to do the things described on this page.
Role: Organization admin, Site admin, Space admin
To directly import your data using the ClickUp importer:
  1. From the navigation bar, select Spaces, then Create space, then Import data from the sidebar.
    • You can also navigate to the page through your settings. Select Settings (⛭), then System, then External System Import on the sidebar.
  2. Select ClickUp from the list of apps.
  3. Select Connect Workspace in the OAuth screen to provide access to your ClickUp account.
  4. Select where you’d like to import your data from. First select your ClickUp Workspace, Space, then Lists (up to 10).
    • Once you’ve selected your Lists, you'll see an About your ClickUp project section showing you the number of work items that will be imported.
  5. Select Next.
  6. Create a new space in Jira. This is where your data from ClickUp will be imported. You can customize the name of the space, its access, and key type. Then select Next.
    • The Key will automatically be selected for you. You can customize it as needed. You can also modify the space name and key later from your space settings.
    • If you’re creating a new software space, your data will be imported into a kanban template.
  7. Next, review the details for your new space. The Review details screen will summarize how your ClickUp data will be imported.
    • Space hierarchy: View how the ClickUp Lists will be structured in Jira.
    • Field mapping: View how your ClickUp standard and custom fields will be mapped in Jira. Use the dropdown lists to customize each field.
    • Status mapping: View how your ClickUp statuses are mapped in Jira. Use the dropdown lists to customize each status.
    • Import users: You can choose to import user data such as assignees, mentions, and people to your new space.
      • App admins can only move existing users from the site into the space. To add new users, contact an organization admin to invite them before proceeding with the import.
    • Import attachments: You can choose to import attachments to your new space.
    • Import comments: You can choose to import comments to your new space.
  8. Select Import when you’re ready to start creating your new space and importing data.
The importer will automatically start bringing over the data from ClickUp in the background. You can continue to work on other things in the meantime, while following the progress of your import at the top of your screen.
Once the data is imported, refresh the page to see the work items on your board.
If your import fails or is partially complete, you should be able to download an error log at the end of the import. Use the troubleshooting guide to fix errors and try importing your project again.
Contact support if you’re facing further issues with your import.
ClickUp import times and rate limit
The time it takes to complete the import of your Lists to Jira will vary depending on your ClickUp plan. This is because ClickUp applies rate limits per token.
Structure your data in Jira
When you use the ClickUp importer, it directly pulls information from your account and creates a space in Jira with a similar structure and hierarchy.
Here’s how your ClickUp data will be structured in Jira:
  • Statuses will be imported as statuses.
  • Lists will be imported as epics and work items.
  • Tasks will be imported as tasks. Each subtask and nested subtask will be imported as subtasks linked to its respective parent task.
Once your Lists are imported, you can customize the hierarchy.
Customize your statuses
We’ll automatically map your ClickUp statuses to a Jira status — To Do, In Progress, or Done. You can select a status from the list, or add a new custom status for future use.
To select or add a new status:
  1. Select the dropdown of the status you want to change.
  2. Select a status from the list, or type in the name of the new status you want to add.
    1. You can also start typing to search.
  3. Select the status you want.
  4. If you added a new status, confirm the Status name and Status category, then select Add. Read about statuses
  5. You should now see your newly added status in the dropdown field.
If you are importing to a company-managed space, your dropdown will also include statuses from your existing Jira site.
Edit fields in your Jira space
You can customize how your ClickUp fields are imported to Jira.
The review screen will summarize how your data will be mapped to the new space. Select Field mapping — this screen will show how your ClickUp data is automatically mapped.
Here you can:
  • Alter how your ClickUp data is mapped.
  • Use the toggle buttons to choose not to include specific fields in your import.
To customize your fields:
  1. Select the dropdown of the field you want to edit.
  2. You can either select an existing field from the options provided or select a custom field that best suits the format of your field. If you select a custom field, it’ll take the same name as your ClickUp field.
Once you’ve customized your fields, select Back to review details to save your changes and go back.
Supported ClickUp fields
Both ClickUp and Jira have two types of fields.
  • Standard or system fields: These fields are “built-in” or part of the software by default.
  • Custom fields: These fields are customizable based on the user’s needs.
The data from your ClickUp fields can map to either system or custom fields in Jira in the following manner:
ClickUp standard field
Compatible Jira system field
Compatible Jira custom field
Assignee
Assignee
Checkbox
Dropdown
Date
Date
Description
Description
Dropdown
Dropdown single select
Due date
Due date
Email address
Short text
Files
Labels
Labels
List color
Short text
List name
Epic
Location
Long text
Money
Short text
Number
Number
People
People
Phone
Short text
Priority
Priority
Rating
Dropdown
Relationships
Linked work items
Start date
Start date
Sprint points
Number
Status
Status
Tag
Label
Task name
Task tag
Task tag
Task types
Work types
Text
Short text
Text area
Long text
Time tracked
Time tracked
Time estimated
Short text
Website
URL
ClickUp fields that aren’t a part of the standard list will be created as custom fields in Jira.
Unsupported ClickUp fields
The following ClickUp field types can’t be mapped to either system or custom fields in Jira and aren’t supported as part of the import:
  • Task cover image
  • Formula
  • Progress (auto)
  • Progress (manual)
  • Rollup
  • Tasks
Some comment types are also not supported:
  • Task mentions
  • Embedded view
  • Replies to comments
