Jira is getting a fresh new look and navigation
We’re in the process of rolling out these changes and the documentation may not match your experience. Bear with us while we update it to reflect the new changes. More about navigating the new Jira
Use Jira Work Management for task management
The task management project template sets you up with the most basic workflow for creating and completing work.
There are two steps in the workflow: To do and Done.
Use this project type for...
  • Business as usual tasks such as preparing reports or presentations
  • Ad hoc tasks such as training a new team member
  • Small, recurring tasks such as updating time-sheets or ordering supplies.
Set due dates & reminders
For the type of tasks you're doing, you may want to set due dates and reminders. The assigned person will then be automatically notified when the task is due. If you also become a watcher on the issue, you will be reminded as well.
See Scheduling an issue
Create sub-tasks
If a task that you add is actually a group of smaller tasks, you can create sub-tasks and assign them to different people. The task will not be able to move to Done, until all the subtasks are complete as well.
See Creating issues and sub-tasks
Task recycling
As tempting as it may be to recycle the small recurring tasks, and put them back in To do, don't. It'll affect reporting for the project and your team won't get an accurate picture of how much they have completed. Instead, choose ••• > Clone and create a copy of the issue to make sure you can accurately record and report on all work.
See Reporting
Manage activity on the board
Use the Jira Work Management board to track incomplete tasks, add new ones and check what has been done. The board gives you a quick view of what is overdue (if you are using due dates) and who is assigned to tasks so you can follow up.
See Working with boards.
Customize issues
The table below shows the specifications for default issues in a task project. Jira Work Management admins can customize these defaults. For example, they can add other issue types to the project, or add new fields to this issue type. See Configuring issues.
Issue type
Task and subtask
Issue fields
Summary, Issue Type, Reporter, Attachment, Due Date, Description, Assignee, Priority, Resolution and Labels
Resolutions
Done, Won't Do, Duplicate and Cannot Reproduce
Priorities
Highest, High, Medium, Low and Lowest
