Jira is getting a fresh new look and navigation
We’re in the process of rolling out these changes and the documentation may not match your experience. Bear with us while we update it to reflect the new changes. More about navigating the new Jira
Use Jira for operations projects
Operations teams do all kinds of projects, ranging from office moves to site audits.
The business projects Project Management template is an ideal base project for managing short-term and delivery-based projects.
Workflow with to do, in progress, and done statuses.
About the template
  • Ideal for projects of any size, any duration, and for any deliverable.
  • Can be used to track milestones and set time limits for activities
  • Easily customized to include additional steps, such as review, blocked, etc.
Stay on top of everything
You're able to view the status of every task on the board, including who is working each thing, and if it is overdue.
Board showing operations tasks in various stages of the workflow.
Add milestones using versions
Projects often have 'checkpoints' or milestones that need to be reached in order to keep the broader project on track. In business projects you can use versions as milestones. Once you've set up version, you can organise work into different versions.
See Organizing work with versions
Report back to management
Projects are usually made up of well-defined, specific, measurable activities that have one major deliverable or goal. This makes project reporting even more critical to ensuring things get delivered on time. business projects includes built-in reporting, but you can also use your dashboard, and custom filters based on your searches to monitor activities.
Customize
Jirais highly customizable. Some common customizations include:
  • Adding additional steps to the workflow (such as approvals), to fit the way a project works.
  • Changing the layout of tasks to capture specific information.
  • Use labels to track groups of issues related to project phases or workstreams.
