Transition work items through a workflow
When your board is grouped by status, you can drag a card on the board to a different column if there’s an available transition set up or if there’s a global transition applied.
Here’s another way to move a work item to a different status:
  1. Open the dialog of the work item you’d like to transition.
  2. Select the dropdown to change the status at the top right corner.
View your project’s workflow in a company-managed project
If you’d like to view your business project's workflow, you can:
  1. Next to the name of your project in the sidebar, select More actions (•••), then Project settings.
  2. Navigate to Workflows.
  3. Select View as text or diagram.
Only Jira admins (in company-managed projects) can edit workflows. Learn how to edit a workflow
View your project’s workflow in a team-managed project
If you’d like to view your team-managed business project's workflow, you can:
  2. Navigate to Work types.
  3. Select Edit workflow at the top-right of the screen.
You can edit the workflow for each work type within your business project.
Only project admins (in team-managed projects) can edit project workflows. Learn how to edit a workflow
