Import data directly from Trello into Jira
Moving your work from Trello to Jira just got easier. You can now directly import data from Trello into Jira using the Trello importer. The importer directly pulls information from your Trello account, saving you the effort of manually moving data and ensuring the project information is relevant and accurate.
Use the Trello importer
You need to be an organization, site, or Jira administrator to use the importer.
In addition to administrators, users with permission to create team-managed projects can create and import data into team-managed business projects but won’t be able to move users. Instead, user fields in the new project will be unassigned and user tags in comments will appear as plain text.
Read about Jira’s global permissions
To directly import your data using the Trello importer:
  1. Next to Projects in the sidebar, select Create project ().
  2. Select Import data on the sidebar.
    1. You can also navigate to the page through your settings. Select Settings (⛭), then System then select External System Import on the sidebar.
  3. Select Trello.
  4. Select the Trello workspace and the Trello board from where you’d like to move your data. Select Next.
  5. Add a valid email address for each user to import their information into Jira. Select Next once you’re done.
    1. Make sure to provide the correct email address for each user to avoid data loss and to import the right users into the new project. The current release does not support email invites but we’re working on enabling this feature soon.
    2. Note: Users without an email address won’t be added to the project. These users will appear as “Anonymous” or “@trellousername” in the new project.
    3. Product admins can only add existing users from the site. To add new users, contact an organization admin to invite them before proceeding with the import. Any information of new users added on this page by product admins will not be imported.
  6. Name your new project, and select Import.
    1. The Key will automatically be selected for you. You can modify the Project name and Key later in the Project Settings.
The importer will automatically start moving the data from Trello in the background, and the progress bar will indicate the status of your import. Your data will be migrated into a Kanban board. Once the data is imported, it will show on the board view as work items in your new project.
