Get help with Jira Cloud
How can we help you?
Choose the appropriate help resource to get your problem solved faster.
I don't know how to do something
  1. Search Atlassian Community.
  2. Raise a support request.
Something isn't working
  1. Check the Jira knowledge base.
  2. Search Atlassian Community.
  3. Raise a support request.
If you've identified a bug but don't need further assistance, raise a bug report.
I don't like the way something works
Raise a suggestion.
Something else?
If you need help with something else, raise a support request.
About our help resources
Atlassian Support
Our support team handles support requests that are raised in our support system. You need to log in using your Atlassian account before you can raise support requests.
For information on our general support policies, including support availability, SLAs, bugfixes, and more, see Atlassian Support Offerings. For anything security-related see Data protection.
Atlassian Community
The Atlassian Community is where you can ask questions and find answers about all your Atlassian apps. Search current discussions, or ask a new question and have Atlassian staff and experts answer it.
The community is an ideal place if:
  • you are using an unsupported Jira instance or an unsupported Jira platform
  • you are trying to perform an unsupported operation
  • you are developing an add-on for Jira
Jira knowledge base
If there are known issues with a version after it has been released, the problems will be documented as articles in our knowledge base
Atlassian work item tracker
Our official work item tracker records our backlog of bugs, suggestions, and other changes. This is open for the public to see. If you log in with your Atlassian account, you will be able to create work items, comment on work items, vote on work items, watch work items, and more.
Before you create a work item, search the existing work items to see if a similar one has already been created.
Atlassian Government Cloud apps
For help and support, log in and raise a support request.
