Create project components
Components are only available in company-managed projects.
Components let you and your team classify issues so you can easily find and report on them. As a project admin, you can create components that you and your team can then add to issues via the standard component field.
To create a new component:
Next to your project's name in the sidebar, select More actions (•••), then Project settings.
Select Components in the sidebar, then select Create component.
Give the component a name.
Optionally, fill in the following values:
Description - Describe the component so other can understand what it’s used for
Component lead - A person designated as being responsible for work items that have the component
Default assignee - A person who is automatically assigned to the work item if the component is added
Select Save.
Once you’ve added at least one component, a new Components item will appear in the project view navigation. There, you and your team can view existing components and the work items that have that component.
