Create or delete a Jira Product Discovery project
A Jira Product Discovery project holds all your data and insights. It is where you can play around with possible ideas and prioritize upcoming work for your team.
Create a project
Before you begin
You need to have the global permission “Create team-managed projects”
To create a new project:
On the left navigation bar, select Projects >
Select Product Management.
Product discovery, prioritization, and roadmapping come with sample ideas, views and fields to get you started. You can start fresh with a blank template.
3. Add your project details, and then select Create project.
After a few seconds, you land on your new project.
Standardize your product management practices
You can keep project configurations consistent across all your product discovery projects by reusing an existing project’s setup when creating a new one. This copies fields, views, and workflows from the selected project.
To create a new discovery project by reusing configurations from another project:
On the left navigation bar, select Projects > or on the project page, select Create project.
Select Reuse an existing project configuration.
Pick an existing project to copy its configurations and select Create project.
Make sure you’re using global fields in your original project to avoid creating duplicate project fields.
Delete a project
You can get rid of projects that you no longer use by moving them to trash.
Before you begin
You need to be a Jira administrator or project admin in Jira Product Discovery.
To delete a project:
In the top navigation bar, select Projects > (…) Manage projects
Find the needed project, and then select (…) > Move to trash.
On a confirmation dialog, click Move.
The project will be available in the trash for 60 days after which it will be permanently deleted.
