Manage space and global fields from your space
In your space, field management is centralized under Space settings. From this page, you can add and remove global custom fields and hide system fields.
Create a new space-scoped field
手順
Go to your space in Jira Product Discovery.
Next to your spaces’s name in the sidebar, select More options (…) > Space Settings > Fields.
[フィールドを作成] をクリックします。
作成するフィールドのタイプを選択して [作成] をクリックします。
詳細を追加します。
This field will now be available in the space.
Add a global field to your space
Global fields can be reused across spaces. For more information, check how to create and manage global fields.
手順
Click Add global field and find the field you want to add to the space.
All - Lists all global custom fields available on the site.
Discovery - Lists global fields created in the Jira Product Discovery global field page.
Jira - Lists global fields from other Jira apps.Check the details of the select field, and click Add.
Global fields can only be created and edited from the global field page. A jira admin can click Global fields → to access this page
Migrate values from a space field to a global field
To replace an existing space field with a new global field, you can copy its values into the new global field. When migrating a space field value, the different values added to a field will be copied into the new global field across all ideas for this space.
はじめる前に
You must be a space admin to migrate field values to global fields.
You can migrate values between two fields of the same type.
The global field needs to be added to the space.
手順
Next to your space’s name in the sidebar, select More options (…) > Space Settings > Fields.
Select Migrate field values to a global field.
Select a space field from the dropdown.
Select the global field where you want to copy the values or create a new one.
If prompted, select Map options to review and map field options, and then select Map.
Select Migrate values.
You can now see values under the global field for all ideas under this space.
Tip
Once you've migrated values and your global field has been populated, you can replace your space field with the global field in your views. You can then eventually delete the space field to avoid confusion.
Remove fields from a space
はじめる前に
Beware that removing fields from a space might impact views:
When a space field is deleted, values get lost.
If you remove (not delete) a global field from the space, it still exists at the site level and in other spaces.
System fields cannot be deleted or removed, only be hidden in views.
手順
削除するフィールドを選択して、アクションを確定します。
システム フィールドを非表示にする
Space admins can now hide system fields that aren’t in use in their Jira Product Discovery spaces.
システム フィールドを非表示にするには、次の手順を利用します。
任意のシステム フィールドを選択し、次のアイコンをクリックします。
目のアイコン > [非表示] をクリックします。
この内容はお役に立ちましたか?
