Using Not Equals on a Resolution does not return Unresolved Issues
Symptoms
  • When using the resolution = Unresolved JQL issues are returned.
  • When using resolution != Fixed, issues with an Unresolved resolution are not returned.
The Unresolved status is considered to be a null value, so not equals will not return it.
Workaround
Use the resolution != Fixed OR resolution is EMPTY JQL to return these issues.
ℹ️ If using a project in this query, ensure to use parenthesis, for example project = CAPTAINPLANET AND (resolution != Fixed OR resolution is EMPTY).
Updated on September 25, 2025
