Transition not appearing for Issue Type Test when using Zephyr
Symptoms
When using Zephyr, you need to create the Test Issue Type, however, it's not respecting the Workflow associated to it (you can't find the needed transitions).
The workflow toolbar for a test is not displayed by default in Zephyr's configuration.
Workaround
Change the default configuration in Zephyr's General Configuration page (see here) to display the workflow toolbar for issues of type "Test".
Updated on September 25, 2025
