Project Lead cannot be altered for a specific project for JIRA 7
Problem
Unable to update the project lead
  • Clicked the 'Update' button, nothing happened and no any error message.
  • The loading circle occurs very shortly but it just stay on the same popup page.
  • Upgraded from JIRA 6.x to JIRA 7
Diagnostic Steps
  • Go to JIRA Administration > Projects > Select Project > Edit Project
  • Verify the project name character counts
This is a bug caused by the introduction of the project length name limit < 20 characters
  • If there is projects which holds project name with >20 characters, when migrated, you wont be able to edit the project lead
Workaround
Rename the project name accordingly to <20 characters
Resolution
Go to Settings (cog icon on top right) > System > Maximum project name size and increase the maximum allowed characters here.
Updated on September 25, 2025
