Project Info Panel Does not Display
Symptoms
JIRA displays following message "Note: The 'Project Information' panel is not available. "
Resolution
  1. Verify that Project Panels Plugin is not disabled.
  2. Ensure that both 'Components' and 'Fix For Versions' are not hidden in ANY associated field layout scheme.
Updated on September 25, 2025
