Project Automation rule is not running when an issue is created
Project Automation rule is not running when an issue is created, however, it is running properly for other events.
✔️ For the same Project area, other rules are running fine;
The rule is not triggered independently of the new action executed (add comment, create sub-task, send notification);
✔️ The rule runs if the trigger is changed, for instance, to "field value changed";
✔️ The rule is triggered for other Project Areas, using different Workflows;
The rule is not triggered for Project Areas using the same Workflow.
The workflow used by the issue type does not have the "Fire a Issue Created event that can be processed by the listeners." event at the Post-functions for the new transition.
  • Edit the workflow;
  • Click at the new transition to show the menu options;
  • Select Post-Function;
  • Add a new event and select "Fire an Event" and the "Issue Created" option.
Updated on September 26, 2025
