JIRA Does Not Start due to Index Lock File(s)
Symptoms
JIRA will not start. Additionally, you will find an error similar to the following in the logs:
2010-10-07 10:48:22,789 ERROR [atlassian.jira.upgrade.ConsistencyCheckImpl] ************************************************************************************************************* Index lock file(s) found. This occurs either because JIRA was not cleanly shutdown or because there is another instance of this JIRA installation currently running. Please ensure that no other instance of this JIRA installation is running and then remove the following lock file(s) and restart JIRA: /app/jira/atlassian-jira-3.13.5-standalone/temp/lucene-90906deb6b27ad5e03a15a2bea317937-commit.lock Once restarted you will need to reindex your data to ensure that indexes are up to date. Do NOT delete the lock file(s) if there is another JIRA running with the same index directory instead cleanly shutdown the other instance. *************************************************************************************************************
Resolution
  1. Ensure no instance of JIRA is running.
  2. Delete the mentioned .lock files. See the error message for the location of the lock file, or refer to How do I unlock my JIRA home directory?
  3. Start JIRA.
  4. Re-index to ensure indexes are up to date. See Search Indexing.
Updated on September 25, 2025
