Jira Data Center: Issues not found when searching long comma-separated values
Jira search fails to find issues when multi-line text fields contain long strings without spaces. Add spaces after commas to fix indexing.
You encounter this issue if:
  • You have a Text Field (multi-line) containing a long list of comma-separated values (for example: IDs, codes, or references).
  • You run a JQL search for a specific part of that value.
  • Expected: The search returns the issue.
  • Actual: The search returns no results, even though the text exists in the field.
Example
Field value: AB-CDE12F34-GHIJKLMNOP-613,AB-CDE12F34-GHIJKLMNOP-637,AB-CDE12F34-GHIJKLMNOP-590
JQL Search: "Custom multiline" ~ "AB-CDE12F34-GHIJKLMNOP-613"
Result: No issues found.
Jira’s search uses an indexer that is optimized for natural language (sentences, words). For indexing it:
  • splits text into tokens (searchable pieces) using rules designed for normal text,
  • treats long comma-separated alphanumeric strings without spaces as a single token (similar to a long number),
  • drops any token longer than 255 characters for indexing.
If your comma-separated list has no spaces and exceeds 255 characters, Jira treats the entire list as one oversized token and ignores it during indexing. This prevents you from searching for individual items within that list.
This is a known limitation of the current indexing behavior.
Add a space after each comma in the multi-line text field. Spaces force the indexer to split the string into separate, smaller tokens that fall under the 255-character limit.
Before
Correct search string
AB-CDE12F34-GHIJKLMNOP-613, AB-CDE12F34-GHIJKLMNOP-637, AB-CDE12F34-GHIJKLMNOP-590
Note: You can also use a semicolon (;) or a new line to separate values, as these also trigger the indexer to create new tokens.
Updated on May 26, 2026
