Issue URL links contain undefined for Project Key
Problem
After upgrade Jira, when attempting to access an Issue link, the URL is redirected to replace the project key with the word undefined.
For example, when clicking on issue link for <Jira-BaseURL>/browse/ABC/ABC-13598, you are incorrectly redirected to <Jira-BaseURL>/browse/undefined/ABC-13598.
The image below may be displayed after the redirect:
This was found to be caused by an unsupported version of third party app, Smart Attachments.
There are two potential solutions to this:
  • Update Smart Attachments app to the most recent version via Settings > Manage Apps > Manage Apps > Update (on the Smart Attachments app)
  • Uninstall the Smart Attachments app from the Jira instance via Settings > Manage Apps > Manage Apps > ( select Smart Attachments app ) > Uninstall
Updated on September 25, 2025
