Automation for Jira: Priority set within the rule is not copied when issue is cloned to another project
When an Automation rule is created to edit the priority of an issue and the issue is cloned to another project, the set priority within the rule is not copied to the new issue.
Jira Cloud
Automation keeps a buffer to make things run faster, however, sometimes the buffer will not refresh quickly. Buffer can be a great thing to avoid any delay, but it can also cause a setback.
Add Re-Fetch issue data before cloning the issue
Updated on September 25, 2025
