Bi-directional sync product between Jira and Jira Align
This article describes steps to sync the Product between Jira and Jira Align
The steps to be followed are as below:
In Jira
  • Create a Product custom field of type "Select List (single choice)" in Jira > Settings > Issues > Custom Field
  • Add values to the Product custom field by going to '3 dots' > Context and Default value
  • Enter the Jira Product values
  • Assign the Jira Product custom field to the screens where you want the field to be applied
In Jira Align
  • Jira Align > Admin > Jira setup > Product custom field. Enter the Jira Product custom field valu
  • Click on 'Configure' next to Product custom field and map the Jira Align product to Jira Produc
  • Make sure the product field is enabled in Jira Align as mentioned here How to connect a Feature to a Product - Jira Align.
Updated on September 26, 2025
