Tempo custom field values are not appearing in Automation rules
When you are using the Third party app, Tempo timesheets, you might see that not all values that exist for tempo field is showing under the edit issues rule.
This is because of the existing limitation in Automation, where a tempo account does not work with more than 1000 accounts.
Automation always makes the API call below irrespective of the search string
https://<site name>.atlassian.net/rest/api/2/field/io.tempo.jira__account/option?maxResults=1000
This is currently logged as a bug. The details can be seen from this link Automation limit with Tempo Accounts
You can add the value of the tempo account through Advance edit for Automation in an edit issue field section as shown below.
This is the JSON that you can use to add the tempo account value. In the example below "customfield_12401" would be the custom field ID of the tempo account and "ID number" needs to be replaced with the ID number of the value field.
"fields": {
"customfield_12401": "ID number"
}Was this helpful?
