How to count the number of times an issue was reopened using Automation for Jira
At times, there could be a requirement to see how many times an issue (task, bug etc.) has been reopened without a need to create a specific reopen status in the workflow but a field that would either show whether the issue was reopened or not or how many times it got reopened.
  1. Create a custom field named Reopen Count with the Number type and set the default value to 0
  2. Create an Automation Rule as described below:
    • Add the trigger Issue Transition to fire if an issue transitions from Done > To Do (Select the transition status as per the workflow definition)
    • Add the action Edit Issue fields to update the value of the custom field ReOpen Count with the below smart value,
{{#=}}{{issue.ReOpen Count}} + 1{{/}}
Update custom field using smart value
3. Make multiple transitions on an issue from the status Done > To Do, and observe that the ReOpen Count custom field value keeps being incremented by 1 (in the example below, the issue was transitioned 3 times):
Updated on September 25, 2025
