Resolve Issues with Bulk Operations in Jira Automation Cloud
When doing bulk operations to update a certain field on multiple issues at the same time, we tend to see that the field update does not happen as expected, and some updates may not be completed.
The operations happen too fast for the automation to update all fields at once.
  1. Access the rule in question.
  2. Immediately after the trigger, add an action Re-fetch Issue Data save
    Re-fetch component in Jira automation
  3. Publish the rule.
The re-fetch action will fetch the information from the issues again so as not to miss any of the issues.
For field updates using Bulk Action, the automation will not trigger if the "Field Value Changed" with "Edit Issue" or "Assign Issue" operation is set. This is a current limitation and here are the tracked it AUTO-104 - Better support for bulk actions in Automation
Updated on September 25, 2025
