Authenticating OAuth 2.0 for outgoing web requests in Jira Automation rules
How to authenticate OAuth 2.0 for outgoing web requests in Automation.
To authenticate over OAuth, you'll need two specific outgoing web requests. The first request will generate a token that's used in the second request to obtain the credentials needed for subsequent web requests.
First request
Common values for the Content-Type header are application/x-www-form-urlencoded ( shown below ) or application/json.
Webhook URL: https://host/token.oauth2/grant_type=client_credentials.  Content-Type set to application/x-www-form-urlencoded.  The HTTP method is POST.  "Wait for response" is checked.  Custom data field contains: client_id={value}&client_secret={value}.
Second request
Set the value for the Authorization header to Bearer {{webhookResponse.body.access_token}} as shown below. You may need to include additional values in the form body as well.
A Jira automation rule action for sending web requests. Includes fields for URL, headers, HTTP method, webhook body, custom data, and wait for response options.  Provides instructions for accessing webhook response data using smart values.
Values provided in the webhook body are not HTML URL encoded. If a value contains a special character, $ for example, it is sent as-is instead of its HTML URL encoded equivalent of %24. If authentication is failing unexpectedly, convert special characters in values to their HTML URL encoded equivalent
Updated on September 26, 2025
