Add a hyperlinked URL in the description field using Jira Automation
You would like to add a hyperlinked URL in a text (ex:description) field using Jira Automation (A4J)
To create a hyperlink in the description field using Jira Automation, you can use the following format:
[Click here|https://google.co.in]
  1. Access Jira Automation:
    • Navigate to your Jira instance and click on "Project Settings" for the relevant project.
    • Select "Automation" from the sidebar menu
  2. Create a New Rule:
    • Click on the "Create Rule" button
    • Choose the appropriate trigger (e.g., "Issue Transitioned" if you want the hyperlink to be added when an issue transitions)
  3. Add an Action:
    • After selecting the trigger, click on "New Action"
    • Choose "Edit Issue" from the list of actions
  4. Configure the Edit Issue Action:
    • Select the "Description" field (or any other multi line text field) to edit
    • To add a hyperlink text to this field, use the following format
    • Click "Save" to create the rule
    • Test the rule to ensure the hyperlink is added correctly to the desired field
  5. Save and Test the Rule:
    • Click "Save" to create the rule.
    • Test the rule to ensure the hyperlink is added correctly to the description field.
Updated on September 25, 2025
