Confluence Question Plugin Encoding Issue in Question's Title on Environment with SSL and Proxy
Symptoms
When creating question in Confluence Question using special character like Russian (Cyrillic) or other than International alphabet, the title will be encoded wrongly in the Confluence Question editor. This happens when the instance is using SSL and proxy and only happens in Confluence Question not during creating normal page.
Diagnose the issue following Troubleshoot Character Encoding documentation.
It's caused by the following:
Missing
useURIValidationHackattributeuseBodyEncodingForURIattribute is set totrueNo Tomcat termination in the connector tag
Resolution
Add the following attribute in the SSL connector and ensure the SSL termination is configured in Tomcat:
useURIValidationHack="false"useBodyEncodingForURI="false"className="org.apache.coyote.tomcat4.CoyoteConnector"
