Using automation to edit Assets custom field by matching text from issue description
This article covers steps to create an automation rule that searches the Jira issue description for a pattern and tries to match it with the Assets object. When a match is found, it updates the Assets custom field on the issue with the corresponding value.
The requirement is to use Jira automation to update Assets custom field by doing a text pattern match against the Jira issue description and the value stored on the Assets schema object.
Here is a sample of the automation rule that can achieve this requirement :
  1. "When: Manually triggered"
  2. "Then: Edit issue fields" to edit the Assets field using something like: "Name" like {{issue.description.match("Service:|s|w*|s-|s(\w*)|s")}}
NOTE: As you can see, we can add the AQL directly on the 'Edit Issue' action.
Updated on September 26, 2025
