Use incoming webhooks with smart values in Automation for Jira
Automation for Jira has a trigger that reads incoming webhooks, both in on-premises and cloud instances.
When we use this trigger, we can use the {{webhookData}} smart value to represent the POST payload.
If the {{webhookData}} doesn't work, try using the {{webhookResponse.body}} smart value instead.
Retrieve a specific part of a webhook payload
The smart value {{webhookData}} gets the root of the JSON payload. To get a specific property from the larger payload, we can use {{webhookData.someValue.childValue}}.
Let's consider the payload below:
"self": "http://localhost:48205/j8205/rest/api/2/issue/10137",
"id": 10137,
"key": "SD-38",
"fields": {
"issuetype": {
"self": "http://localhost:48205/j8205/rest/api/2/issuetype/10103",
"id": 10103,
"description": "Created by Jira Service Desk.",
"iconUrl": "http://localhost:48205/j8205/secure/viewavatar?size=xsmall&avatarId=10701&avatarType=issuetype",
"name": "Service Request",
"subtask": false,
"fields": null,
"statuses": [],
"namedValue": "Service Request"
"summary": "Cannot turn on my laptop",
...Some example data from this payload:
Key -
{{webhookData.key}}Summary -
{{webhookData.fields.summary}}Issue type ID -
{{webhookData.fields.issuetype.id}}Issue type name -
{{webhookData.fields.issuetype.name}}
ℹ️ If the incoming JSON has periods in the field, such as "container.name", we just need to add double quotes to the smart values, which will look like {{webhookData."container.name"}}
Confirm payload data from the JSON path
Here are some examples of ways to test the JSON path to get the right data in the smart values, so you can get it right on your first try!
First, you need a sample from the webhook payload data. This can be obtained by sending a webhook to a webhook test site (like https://requestbin.com) or by intercepting the message by enabling Jira's HTTP access logs and HTTP dump from the System > Logging and Profiling screen and then checking the request data.
ℹ️ After testing, disable both the HTTP dump and access logs to avoid performance issues.
With a sample JSON, either:
Use an online JSON path tool like https://jsonpathfinder.com/
Use an IDE like Visual Studio Code to find the path:
Test using a command line:
In Linux/Mac OS, use a jq command, such as:
jq '.fields.issuetype.name' webhook.jsonIn Windows, we can use Powershell's ConvertFrom-Json:
(get-content webhook.json | convertfrom-json).fields.issuetype.name
