UPM does not start due to Invalid keystore format when running JIRA through SSL
Symptoms
In JIRA, it is not possible to access the Universal Plugin Manager as it fails to start during the JIRA startup, which causes other plugins to become unusable as they depend on the UPM for license management. Also, the following appears in the atlassian-jira.log:
2013-04-26 08:14:53,550 Spring executor 4 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.upm.atlassian-universal-plugin-manager-plugin
org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'linkBuilder' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Unsatisfied dependency expressed through constructor argument with index 1 of type [com.atlassian.upm.PluginAccessorAndController]: : Error creating bean with name 'pluginAccessorAndController' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Unsatisfied dependency expressed through constructor argument with index 9 of type [com.atlassian.upm.pac.PacAuditClient]: : Error creating bean with name 'pacAuditClient' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.upm.pac.PacAuditClientImpl]: Constructor threw exception; nested exception is org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'pacAuditClient' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.upm.pac.PacAuditClientImpl]: Constructor threw exception; nested exception is org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'pluginAccessorAndController' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Unsatisfied dependency expressed through constructor argument with index 9 of type [com.atlassian.upm.pac.PacAuditClient]: : Error creating bean with name 'pacAuditClient' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.upm.pac.PacAuditClientImpl]: Constructor threw exception; nested exception is org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'pacAuditClient' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.upm.pac.PacAuditClientImpl]: Constructor threw exception; nested exception is org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:591)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:193)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'pluginAccessorAndController' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Unsatisfied dependency expressed through constructor argument with index 9 of type [com.atlassian.upm.pac.PacAuditClient]: : Error creating bean with name 'pacAuditClient' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.upm.pac.PacAuditClientImpl]: Constructor threw exception; nested exception is org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'pacAuditClient' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.upm.pac.PacAuditClientImpl]: Constructor threw exception; nested exception is org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context
at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:671)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:610)
at org.springframework.beans.factory.support.ConstructorResolver.resolveAutowiredArgument(ConstructorResolver.java:622)
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:584)
... 22 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'pacAuditClient' defined in URL [bundle://94.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.upm.pac.PacAuditClientImpl]: Constructor threw exception; nested exception is org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
... 38 more
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.upm.pac.PacAuditClientImpl]: Constructor threw exception; nested exception is org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
... 53 more
Caused by: org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context
at org.apache.http.conn.ssl.SSLSocketFactory.getSocketFactory(SSLSocketFactory.java:175)
at org.apache.http.impl.conn.SchemeRegistryFactory.createDefault(SchemeRegistryFactory.java:49)
at org.apache.http.impl.conn.PoolingClientConnectionManager.<init>(PoolingClientConnectionManager.java:93)
at com.atlassian.upm.pac.PacAuditClientImpl.<init>(PacAuditClientImpl.java:66) <+3> (NativeConstructorAccessorImpl.java:39) (DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
... 55 more
Caused by: java.security.KeyStoreException: problem accessing trust storejava.io.IOException: Invalid keystore format
at com.sun.net.ssl.internal.ssl.TrustManagerFactoryImpl.engineInit(TrustManagerFactoryImpl.java:55)
at javax.net.ssl.TrustManagerFactory.init(TrustManagerFactory.java:230)
at org.apache.http.conn.ssl.SSLSocketFactory.createSSLContext(SSLSocketFactory.java:229)
at org.apache.http.conn.ssl.SSLSocketFactory.createDefaultSSLContext(SSLSocketFactory.java:358)
... 64 more
JIRA is configured to run through SSL in the setenv.bat/sh file (or service) and using a keystore.pkcs12
This happens because JIRA is trying to read the keystore file as .jks, which is the default extension of keystore files; however, the keystore is actually a pkcs12 file, and this was not specified in the setenv.bat/sh (service).
Resolution
To resolve this, it's needed to specify the keystore type as well:
Stop JIRA;
Add
-Djavax.net.ssl.trustStoreType=pkcs12as a startup option.Restart JIRA.
For more information on how to set this in JIRA in the Setting properties and options on Startup doc.
