Stuck Assets Re-index Caused by Duplicate Attribute Values Removal
After upgrading to 5.12+ and 5.16+, the Assets re-index might be stuck at a different percentage or very slow.
Log files to investigate stuck re-index
  • Asset indexing does not complete and halts at different percentages.
  • Log files show warnings about duplicate object attributes:
    2024-12-06 16:11:42,946+0100 insight-InsightThreadGroup-worker-thread-1 WARN Anonymous user [c.r.j.p.i.s.c.d.dao.sql.AbstractAOService] Found duplicate object attributes for object with id 1906545
  • Threads appear stuck while trying to resolve duplicate attribute values:
    06-Dec-2024 16:45:16.006 WARNING [Catalina-utility-1] org.apache.catalina.valves.StuckThreadDetectionValve.notifyStuckThreadDetected Thread [https-jsse-nio-8443-exec-9...] has been active for [123,549] milliseconds and may be stuck (configured threshold for this StuckThreadDetectionValve is [120] seconds). There is/are [2] thread(s) in total that are monitored by this Valve and may be stuck. java.lang.Throwable at com.riadalabs.jira.plugins.insight.services.core.dal.impl.ObjectDalImpl.findDuplicateObjectAttributeValueIds(ObjectDalImpl.java:524) at com.riadalabs.jira.plugins.insight.services.core.dal.impl.ObjectDalImpl.removeDuplicates(ObjectDalImpl.java:464)
Known bug in Jira 5.12+ and 5.16+
This issue is related to a bug identified in Jira 5.12+, 5.16+, referenced as: JSDSERVER-15551 - Changing Cardinality in Assets may lead to undocumented data removal from the database
The bug causes Assets to attempt removing non-existent duplicate attributes during re-indexing, resulting in blocked threads.
To fix the issue, it's necessary to upgrade Jira Service Management to v.10.2.0+.
As a workaround, you can add the following Dark Feature to disable duplicates handling during reindexing:
assets.index.dedupe.attributes.disabled
Enabling this feature flag might result in duplicate attribute values after imports in the future.
Updated on September 26, 2025
