Startup SQL errors when creating Active Objects schema for Automation for Jira
During Jira startup, Automation for Jira (as all apps and plugins) validate it's own Active Objects tables and try to alter them if needed.
For some databases this may fail and has to be updated manually. The errors may allow Jira and Automation to startup and work, but they won't be functioning optimally if the schema's not what the app expects.
Any Server or Data Center version of Jira Software or Jira Service Management, with Automation for Jira installed or bundled within the product.
Th following warning shows up during Jira startup on the atlassian-jira.log:
WARN anonymous     [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugin.automation.for-jira] failed to create ActiveObjects
On MS SQL Server, for example, the error suggests which object prevented the schema update and why:
2023-01-10 19:30:40,365 active-objects-init-JiraTenantImpl{id='system'}-0 ERROR anonymous [n.java.ao.sql] Exception executing SQL update <ALTER TABLE dbo.AO_589059_AUTOMATION_QUEUE ALTER COLUMN PRIORITY BIGINT NOT NULL> com.microsoft.sqlserver.jdbc.SQLServerException: The object 'df_AO_589059_AUTOMATION_QUEUE_PRIORITY' is dependent on column 'PRIORITY'.
The possible list of blocking objects includes, but is not limited to:
fk_ao_589059_automation_queue_audit_item_id fk_ao_589059_audit_item_project_audit_item_id fk_ao_589059_audit_item_comp_cge_audit_item_id fk_ao_589059_audit_item_cge_item_audit_item_id fk_ao_589059_audit_item_asc_item_audit_item_id pk_AO_589059_AUDIT_ITEM_ID pk_AO_589059_AUDIT_ITEM_ASC_ITEM_ID pk_AO_589059_AUDIT_ITEM_CGE_ITEM_ID fk_ao_589059_audit_item_cge_item_audit_item_component_change_id fk_ao_589059_audit_item_asc_item_audit_item_component_change_id pk_AO_589059_AUDIT_ITEM_COMP_CGE_ID pk_AO_589059_AUDIT_ITEM_PROJECT_ID pk_AO_589059_AUTOMATION_QUEUE_ID df_AO_589059_AUTOMATION_QUEUE_PRIORITY pk_AO_589059_COUNTERS_ID pk_AO_589059_LEGACY_RULE_LINK_ID df_AO_589059_LEGACY_RULE_LINK_LEGACY_ID df_AO_589059_LEGACY_RULE_LINK_NEW_ID fk_ao_589059_rule_cfg_component_parent_cfg_component_id fk_ao_589059_rule_cfg_component_condition_parent_id pk_AO_589059_RULE_CFG_COMPONENT_ID pk_AO_589059_RULE_CFG_PROJ_ASSOC_ID fk_ao_589059_rule_to_label_rule_id fk_ao_589059_rule_tag_rule_config_id fk_ao_589059_rule_schedule_rule_config_id fk_ao_589059_rule_cfg_proj_assoc_rule_config_id fk_ao_589059_rule_cfg_component_rule_config_id pk_AO_589059_RULE_CONFIG_ID fk_ao_589059_rule_to_label_label_id pk_AO_589059_RULE_LABEL_ID pk_AO_589059_RULE_SCHEDULE_ID pk_AO_589059_RULE_STAT_ID pk_AO_589059_RULE_STAT_ROLLUP_DAY_ID pk_AO_589059_RULE_STAT_ROLLUP_HR_ID pk_AO_589059_RULE_STAT_ROLLUP_MIN_ID pk_AO_589059_RULE_STATE_LATEST_ID pk_AO_589059_RULE_TAG_ID pk_AO_589059_RULE_TO_LABEL_ID
The Active Objects implementation in Jira doesn't support dropping indexes, constraints or keys in MySQL and MS SQL Server, thus such changes need to be done directly on the database.
The scripts available for download at Upgrading to Automation for Jira 7.3 or later contain the AO schema changes with the corresponding drop and add directives.
  1. Stop Jira (on all nodes if Data Center)
  2. Backup the database
  3. Run the corresponding script (MySQL or SQL Server)
  4. Start Jira (one node at a time if Data Center)
Updated on September 26, 2025
