Project Shortcuts, Add Links do not appear for specific Projects
When accessing a Project, the Project Sidebar is missing one or both of the following items:
  • Project Shortcuts
  • the 'Add Links' option
Run the following SQL query for the <project_id> in question:
SELECT * FROM "AO_550953_SHORTCUT" WHERE "PROJECT_ID" = '<project_id>';
If you see entries that have no name or shortcut URL in the results, you have the situation described in this KB article. For example, in the query results below entries 3 and 4 are responsible for causing this issue.
ID | NAME | PROJECT_ID | SHORTCUT_URL | URL | ICON
1 | Project management ideas | 11100 |
https://docs.atlassian.com/jira/jcore-docs-097/Project+management
2 | Working in a project | 11100 |
https://docs.atlassian.com/jira/jcore-docs-097/Working+in+a+project
3 | | 11100 | | |
4 | | 11100 | | |
Shortcuts with no name or URL are preventing display of the Project Shortcuts links. Removing these null shortcuts will restore the missing shortcuts.
To resolve this issue the null shortcuts will need to be removed from the database directly. To this:
  1. Shut down Jira and take a database backup.
    1. ⚠️ It is strongly recommended to make a backup before making any direct database modifications to ensure there is a restore point if one becomes necessary.
  2. Run this query for each Project experiencing the issue:
  3. Run this query for each id missing a name and shortcut URL found in step 2:
    DELETE FROM "AO_550953_SHORTCUT" WHERE "PROJECT_ID" = '<project_id>' AND "ID" = '<shortcut_id>';
  4. Restart Jira and validate that your shortcuts and the "add link" option are appearing again.
Updated on September 26, 2025
