Proforma Forms cannot be added to issues with "ProForma does not have an HMAC secret defined. This will cause problems when updating Jira fields from ProForma forms" error in the logs
The steps outlined in this article are provided AS-IS. This means we've had reports of them working for some customers, under certain circumstances, yet they are not officially supported, nor can we guarantee they'll work for your specific scenario.
You may follow through and validate them on your own non-prod environments prior to production, or fall back to supported alternatives if they don't work out.
We also invite you to contact our Community for matters that are outside Atlassian's scope of support!
This only happens on Red Hat Enterprise Linux (RHEL) and Jira configured with RHEL Java
The following messages will be evident in atlassian-jira.log:
2023-08-25 09:36:43,317+1000 http-nio-8080-exec-7 url: 2023-08-25 09:42:31,945+1000 http-nio-8080-exec-10 url: /rest/projects/1.0/sidebar/issue/ICTSD-4223; user: user@domain.com WARN 582x9508x1 du6a6z 192.168.16.132,10.83.5.11 /rest/projects/1.0/sidebar/issue/ISSUEKEY-123 [c.t.p.plugin.util.UserServiceImpl] ProForma does not have an HMAC secret defined. This will cause problems when updating Jira fields from ProForma forms.
Red Hat Java, even though OpenJDK is not officially supported by Atlassian. It has additional security setting security.useSystemPropertiesFile in $JAVA_HOME/conf/security/java.security which inherits the settings from the Operating system by default and which causes this issue
Official recommendation is to use only Supported versions of JAVA, i.e. either Oracle JRE/JDK or Eclipse Temurin
https://confluence.atlassian.com/adminjiraserver/supported-platforms-938846830.html
As a best effort workaround, if using Red Hat Java is must, in this particular scenario the security.useSystemPropertiesFile property in the java.security file can be modified to:
security.useSystemPropertiesFile=false
Removing that line could work to but be mindful that it could affect other applications on the server, you may need to check with the Operating System vendor for further clarifications
Updated on September 26, 2025
