Problem with umlaut characters when importing issues from Mantis using JIRA Importer Plugin
Problem
When issues with umlaut characters are imported from Mantis, JIRA replaces the characters with random character as shown below:
Diagnostic Steps
  • Verify whether both Mantis and JIRA is using UTF-8 encoding.
  • This problem could also be specific to MS SQL
The origin of the encoding problem is Mantis. The Microsoft SQL database supports UCS-2 and does just fine. Mantis however unnecessarily encodes the characters using UTF-8 again. Hence, the database contains another level of character encoding neither the database nor the JIRA importer is aware of.
Workaround
Remove this additional encoding level by decoding all the texts in the database before the import using the JIRA importer.
Updated on September 26, 2025
