Post-function on Create Issue transition appears to not work
Symptoms
You have added a post-function to the Create Issue transition of a workflow e.g set issue field or assign to current user and it doesn't seems to be working.
On observation, this post-function is ordered under the "Creates the issue originally" post-function in the list as shown below.
Exception in the logs
https-openssl-nio-443-exec-57 url: /secure/CreateIssueDetails.jspa; user: test.test@test.com ERROR test.test@test.com 422x3832786x5 t/secure/CreateIssueDetails.jspa [c.g.j.workflow.function.UpdateIssueCustomFieldPostFunction] Unable to update field customfield_15519 - Watchers List in issue [MARCH-3887].java.lang.IllegalArgumentException: User 'test.test@test.com' not found. at ch.beecom.jira.jsu.util.field.FieldTypeConverter.convertValueToUser(FieldTypeConverter.java:1104) at ch.beecom.jira.jsu.util.field.FieldTypeConverter.lambda$convertValueToMultipleUsers$6(FieldTypeConverter.java:1130) at ch.beecom.jira.jsu.util.field.FieldTypeConverter.convertAsDelimitedStringToTypedList(FieldTypeConverter.java:1083) at ch.beecom.jira.jsu.util.field.FieldTypeConverter.convertValueToMultipleUsers(FieldTypeConverter.java:1132) at ch.beecom.jira.jsu.util.field.FieldTypeConverter.convertToRightObject(FieldTypeConverter.java:299) at ch.beecom.jira.jsu.workflow.function.updateissuecustomfield.UpdateIssueCustomFieldPostFunction.performUpdateIssueField(UpdateIssueCustomFieldPostFunction.java:269) at ch.beecom.jira.jsu.workflow.function.updateissuecustomfield.UpdateIssueCustomFieldPostFunction.executeFunction(UpdateIssueCustomFieldPostFunction.java:175) at ch.beecom.jira.jsu.workflow.function.AbstractPreserveChangesPostFunction.executeFunction(AbstractPreserveChangesPostFunction.java:46) at ch.beecom.jira.jsu.workflow.precondition.AbstractPreconditionAwareFunction.execute(AbstractPreconditionAwareFunction.java:69) at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1014) at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1407) at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:606) at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:754) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:578) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:487) at com.atlassian.jira.issue.managers.RequestCachingIssueManager.createIssue(RequestCachingIssueManager.java:195)
Cause#1
Any post-functions placed after the "Creates issue originally" function will not have updates to the issue persisted to the database.
For this to work, it is required that your post-function comes before the "Creates the issue originally" post-function in the order of postfunctions as shown below.
Cause#2
Resolution#1
Re-order the post-functions such that the new post-function comes before the "Creates the issue originally" post-function.
(hovering over the post-functions would expose arrow shaped icons that you can use to change the order of the post-functions)
Older JIRA versions actually automatically created the new post-function under the 'Create the issue originally' post-function, but newer JIRA versions automatically positioned the postfunction correctly.
Resolution#2
Modify the custom field value in PostFunction with a user that exists and is active in JIRA
Notes
This behaviour is being reviewed at JRASERVER-33182 - Update Issue Field post function doesn't fire when set for Create Issue transition.
Updated on September 25, 2025
