Periodic index snapshot job and full re-index running at the same time breaks both
If the periodic index snapshot job runs when a full foreground re-index is started, both can fail as their actions are incompatible and both need to aquire a lock on the index. It will fail at the very beginning of the full re-index job, during the first minute.
Jira Data Center. Verified in at least 8.20.10 and 9.12.11.
If that happens you will see both the below messages in the log. (If you only see one, then the cause is something else.)
and
This is caused by two jobs being incompatible with each other:
The index snapshot job
A default scheduled job is creating an index snapshot every day at 2 am. This creates a zipped copy of the current state of the index and is stored on the filesystem to facilitate fast indexing recovery in case it's needed. (see Backup and recovering your index in https://confluence.atlassian.com/adminjiraserver/search-indexing-938847710.html)
While accessing the index document files an write lock is placed on that file to prevent something from writing to this document file while it is being taken a snapshot of.
Full foreground re-index
When a foreground full re-indexing is performed, the existing index is deleted and a new one is built from scratch. To prevent anything from writing to the index while this is happening, a lock is put on the index.
When the index snapshot job begins it first gets a list of the files to copy. If the snapshot job has not finished by the time the full re-index begins and it manages to get hold of the index lock to continue, it then tries to copy files that have now been deleted by the full re-index job and fails.
If a full re-index is started while the index snapshot job is running, there is a possibility that the snapshot job grabs the index write lock during a very short period of time when it had to be released by the full re-index job.
The result is:
The snapshot job tries to copy files that have now been deleted by the full re-index job and fails
The full re-index job can not get the index lock held by the snapshot job and fails
You may end up with an orphaned index write lock file at
[JIRA-HOME-DIR]/caches/indexesV2/changes/write.lock
This is a bug, JRASERVER-74524. At the time of writing (July, 2024) there is not yet a fix for it.
If you because of this end up with a broken index, for a quick fix you can stop that node, delete the files under '/local/jira-home/caches/indexesV2/' on the same node and restart it. It will then rebuild the index on that from the latest snapshot from another node.
Workaround
Avoid to run a foreground full re-index when the index snapshot job runs at 2 am daily.
