Mobile for Jira breaks commenting on issue in Jira 8.0.X
Problem
When commenting on an issue, the below error pops up:
  • Jira version 8.0.x / SD version 4.0.x
  • Mobile for Jira version 2.0.1 is installed and enabled
Symptoms
  • Commenting on an issue pops up an error.
    • Tested with Service Management issues for both Public and Internal comments.
  • On refreshing the page the comment is actually added.
  • Jira/SD email notifications may be affected.
This is caused by Mobile for Jira add-on whereby version 2.0.1 may not be fully compatible with Jira 8.0.x/SD 4.0.x.
Workaround
Disable Mobile for Jira add-on temporarily.
Resolution
Contact Mobile for Jira Support for a Fix Version.
Updated on September 26, 2025
