JIRA not starting up and 404 shown on JIRA home page
Symptoms
When trying to start JIRA, only a 404 page is visible in the Web browser.
The following appears in the atlassian-jira.log:
2013-05-20 09:16:57,795 main ERROR [NoModule] Error getting datasource via DBCP: JdbcDatasourceInfo{uri='jdbc:oracle:thin:@example.com:1521:BUGZILLA', driverClassName='oracle.jdbc.OracleDriver', username='jiradbuser', password='********', isolationLevel='null', connectionProperties=null, connectionPoolInfo=ConnectionPoolInfo{maxSize=75, minSize=2, maxWait=60000, sleepTime=300000, lifeTime=600000, deadLockMaxWait=600000, deadLockRetryWait=10000, validationQuery='null', minEvictableTimeMillis=null, timeBetweenEvictionRunsMillis=null}} org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (ORA-28001: the password has expired)
This error is seen when using JIRA with Oracle as the database back-end
This is caused by an expired password being used by JIRA to connect to Oracle.
Resolution
  • Create a new password in Oracle for the JIRA user
    • ⚠️ As maintenance of your Oracle database is outside of the scope of Atlassian support, please engage a qualified Oracle DBA for this task
  • Change JIRA to use the new password when connecting to Oracle using one of these methods:
    • Edit the <jira-home>/dbconfig.xml file
    • Run the <jira-install>/bin/config.sh or <jira-install>\bin\config.bat script
Updated on September 26, 2025
