Jira Issues Macro does not create remote links from JQL tables (Data Center and Cloud)
When using Jira Issues Macro in Confluence to link to JQL results, the issues are not linked to the Confluence page.
Jira DC 8.x, 9.x
Confluence 7.x, 8.x
Jira Issues Macro in Confluence will not post remotelinks to Jira when inserting a table. This may be for performance reasons (as there may be a large number of issues on any number of pages), but the functionality currently is only if you add a single Jira link, the remotelink will be posted to Jira. When adding a table based on a JQL, the remote linking does not get invoked from Confluence and there is no remote link created in the Jira issues.
The same behaviour is present on Cloud as well as on-premise instances. There have been suggestions to expand this functionality to tables, but it was decided that would not be pursued at this time:
CONFSERVER-31916 - Adding more than one issue to the JIRA Issues macro on Confluence does not create the reciprocal "mentioned in" issue link on JIRA
CONFCLOUD-31916 - Adding more than one issue to the JIRA Issues macro on Confluence does not create the reciprocal "mentioned in" issue link on JIRA
As a workaround we suggest running a batch update in Jira on the same JQL resultset as added in Confluence, to add the remotelink of the Confluence page where they are displayed. Additionally, any Jira link created individually form a Confluence page will create the remotelink as expected, for additional troubleshooting info see:
"Mentioned in" Confluence page is not displaying on individual Jira issues
Updated on September 26, 2025
