Jira issues generated via the issue collector do not appear in the current list of recent issues within the issue collector.
When a user creates an issue from the issue collector, this issue should show in the Recent Issues section of the Issue Collector administration page, as illustrated below:
In some situations, issues that were recently created by the Issue Collector might not appear in the recent issues list. The purpose of this article is to describe a scenario where issues are missing from this list, and how to fix it.
Jira Data Center on 9.0.0 any higher version.
Run the following JQL query and verify and check if the issues that are missing from the "Recent Issues" list are found in the query result, after replacing <project-key> with the project key and <collectorId> with the collector ID which can be found in the URL while viewing the Issue Collector in the UI:
Please replace the placeholder values
project = <project-key> AND labels = "collector-<collectorId>" AND created >= "-30d"
If the issues that are missing from the "Recent Issues" list are not found in that JQL query, then open this issue in the View Issues page and check the labels field. If this field does not contain the label collector-<collectorId>, then this KB article is relevant and you can move on to the Solution section.
When an issue collector generates an issue, it should automatically assigns a label to the issue with the format collector-xxxxxxxx (where xxxx represents the collector id). Only the issues which have this label will be listed in the "Recent Issues" section of the Collector. By default, the Labels field is included in the Create Issue screen from the screen screen scheme associated to the project. If the Labels field is not visible/configured on this screen (as illustrated in the screenshot below), the label collector-xxxxxxxx will not be added to issues created by the Collector, and such issues will be missing from the "Recent Issues" section:
To resolve this issue, include the Labels field on the create issue screen for the relevant project
