Jira had problems starting up due to database connection
Jira does not start with error message Jira couldn't connect to your database.
8.13.4
  • Analysis of logs shows below mentioned error message in atlassian-jira.log:
2021-12-22 03:00:09,599-0500 localhost-startStop-1 ERROR [c.a.config.bootstrap.DefaultAtlassianBootstrapManager] Could not successfully test your database: com.microsoft.sqlserver.jdbc.SQLServerException: The TCP/IP connection to the host abchost, port 2023 has failed. Error: "abchost. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall.". at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:228) at com.microsoft.sqlserver.jdbc.SQLServerException.ConvertConnectExceptionToSQLServerException(SQLServerException.java:279) at com.microsoft.sqlserver.jdbc.SocketFinder.findSocket(IOBuffer.java:2431) at com.microsoft.sqlserver.jdbc.TDSChannel.open(IOBuffer.java:656) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:2440) at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:2103) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:1950) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1162) at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:735) at java.sql.DriverManager.getConnection(DriverManager.java:664) at java.sql.DriverManager.getConnection(DriverManager.java:247)
A possible cause is that connectivity from database server and Jira is hampered due to the port is blocked by a firewall. So check connectivity of database server from Jira:
  • Make sure connectivity of database from Jira Server instance is fine.
    • Try to connect via any database browser tool.
    • Check connectivity to database with following netcat command(sudo apt-get install netcat):
nc -vnz -w 1 [database server IP] [database port]
  • If database is reachable then output should be like
root@kali:~# nc -vnz -w 1 192.168.1.123 5432 Connection to 192.168.1.123 5432 port [tcp/*] succeeded! root@kali:~#
  • Check if there are any firewall rules configured .
  • Verify the connection properties. Make sure that an instance of the database Server is running on the host and accepting TCP/IP connections at the port.
  • Make sure that TCP connections to the port are not blocked by a firewall. You might have to contact Infrastructure team or Database administrators.
Updated on September 26, 2025
