JIRA 32-bit Installer does not work on JAVA 64-Bit
Symptoms
When executing the Linux 32-bit BIN installer, the process will terminate with the following message:
./atlassian-jira-5.1.2-x32.bin: line 466: /home/immanuel/atlassian-jira-5.1.2-x32.bin.898.dir/jre/bin/java: No such file or directory
The cause of this error is that the server currently installed JAVA-64bit.
Resolution
  1. Please install the x32-runtime of JAVA
Updated on September 25, 2025
