Jelly Service does not work with 'Could not read script string'
Symptoms
When trying to run the Jelly Service, the following appears in the atlassian-jira.log:
2011-11-16 15:18:26,600 ajp-8009-1 ERROR df 918x4418x1 1j1r725 172.28.1.71 /secure/admin/util/JellyRunner.jspa [web.action.util.JellyRunner] Could not read script string. java.io.IOException: expected '=', got 'x' at electric.util.lex.Lex.readChar(Lex.java:371) at electric.xml.sax.SAXParser.parseAttributes(SAXParser.java:685) at electric.xml.sax.SAXParser.parseElement(SAXParser.java:597) at electric.xml.sax.SAXParser.parse(SAXParser.java:330) at electric.xml.sax.SAXParser.parse(SAXParser.java:270) at electric.xml.sax.SAXParser.parse(SAXParser.java:241) at electric.xml.sax.SAXParser.parse(SAXParser.java:207) at org.apache.commons.jelly.parser.XMLParser.parse(XMLParser.java:238) at org.apache.commons.jelly.parser.XMLParser.parse(XMLParser.java:220)
The Jelly script file does not work with UTF-8 encoding (tested in JIRA 4.4.3).
Resolution
Save the file in 'UTF-8 without BOM' encoding
Updated on September 25, 2025
