Issue Collector is not able to create issues from Chrome
Jira Issue Collector fails to submit new ticket with the error: "There was a problem submitting your feedback...". This occurs primarily with custom Issue Collector forms.
Versions 8.21.0,8.13.15,8.20.3,8.22.0,8.13.18,8.20.7,8.20.8 see bug reference below:
The above affected versions are resolved by JRASERVER-73212 - Submitting an issue collector on a non-same origin site results in HTTP 404. However there are some other factors as detailed below, which can cause this error in newer versions of Jira.
Newer versions of Jira, see the diagnosis and solution below:
This problem is related to the cookie attributes for the XSRF value. The XSRF check will fail in the following cases:
  • when the Jira cookie "atlassian.xsrf.token" is not secure and with attribute SameSite=none
  • this can be verified in a HAR file on the requests which contain this cookie
  • additionally, the browser has to allow "third-party cookies"
  • Jira base URL has to be secured by SSL for the secure cookie to be sent
Browser security will not set the cookie correctly if "third-party cookies" are not allowed in Chrome's cookies settings. Further. the Tomcat connector has to have secure="true" and scheme="https".
Also, Jira version needs to be 9.0.0, 8.20.10, 8.22.4 or newer.
Ensure that you are not on a Jira version affected by JRASERVER-73212 - Submitting an issue collector on a non-same origin site results in HTTP 404 Set up Tomcat connector with secure="true" and scheme="https" attributes, as documented in the instructions at: Running Jira applications over SSL or HTTPS
Updated on September 26, 2025
