How to extract a date in long date format from the Summary of an issue using Jira Automation
How to Pull a long date (for example February 20, 2023) from the Summary of an issue and edit the "Start Date" custom field using Jira Automation.
Following JSON code contains smart values which needs to be mentioned in "Additional Fields" section of "Edit Issue" action.
"fields": {
"customfield_10082": "{{issue.summary.match("(\b(?:Jan(?:uary)?|Feb(?:ruary)?|Mar(?:ch)?|Apr(?:il)?|May(?:)?|Jun(?:e)?|Jul(?:y)?|Aug(?:ust)?|Sept(?:ember)?|Oct(?:ober)?|Nov(?:ember)|Dec(?:ember)?) (\b\d{1,2}\D{0,3})?.\s\b(?:19[7-9]\d|2\d{3}))").toDate("MMMM dd, yyyy").format("yyyy-MM-dd")}}"
Automation Preview:
My custom field id for Start Date test is "customfield_10082"
Used Smart value "issue.summary.match" along with Regual Expression(REGEX) which will fetch the date in string format.
Used ".toDate("MMMM dd, yyyy")" to convert string into date format.
Then format date from "MMMM dd, yyyy" to "yyyy-MM-dd"using ".format("yyyy-MM-dd")}}" as my format on custom field is yyyy-MM-dd.
