How to find by whom and when was an issue transitioned from one status to another in Jira using SQL queries
You may need to pull some information about who/when transitioned an issue from one status to another for reporting purposes.
To retrieve this information from Jira UI, you can use the JQL "status changed FROM 'First' TO 'Second'"to filter tickets which were moved from 'First' to 'Second' status. Then go through the history of the tickets manually to see the user who performed the action.
Since the operation above is time consuming, this article offers an alternative to get the data directly from the database using SQL queries.
Any Jira version.
You can retrieve data from the Database using an SQL query as the one below. The sample query is written for the issue ABC-123 and for the transition from First to Second status. Please replace the statuses, issue number and project key with your relevant values.
select i.field,i.oldstring,i.newstring,a.lower_user_name,g.created from changeitem i join changegroup g on g.id = i.groupid join jiraissue j on j.id = g.issueid join project p on p.id = j.project join app_user a on a.user_key = g.author where i.field = 'status' and i.oldstring = 'First' and i.newstring = 'Second' and j.issuenum = 123 and p.pkey = 'ABC';
Updated on September 25, 2025
